On balance the wireless link is probably the neatest option. Moving the pump takes it from a cupboard to a usable store room so is marginally less suitable, though technically sound. But at least I have two viable solutions.
The system is already run through Hive. But moving that upstairs puts it one floor further from the router so anyway would not seem like a good idea, though it seems that doesn't work anyway - the issue is the power to the pump.
From a technical perspective moving tbe pump is tbe simplest option which leaves you with the least number of potential failures.
naylorpd,
davesparks,
