HappyHippyDad
Supporter
Dec 18, 2011
5,379
6,732
405,788
Gloucestershire
Hello all.
Just a bit unsure about polarity on the primary side of this LED driver. 99% certain one relates to live and two to neutral?
The AC input can probably be connected either way round on that.
  • Funny
Reactions: Jim_e_Jib
Reactions: HappyHippyDad
Just got through to them. No polarity. You were correct 😀
Yep. If it doesn't say L - N then there is no polarity. Clever little things lol
Even if it does say L&N it still makes no difference, there is no way for any electrical product to know which way round the AC is connected if its just a two wire connector.
The only thing I've ever seen which makes a difference is a boiler and that's because the flame sensor measures it reading to earth. So if L&N are reversed the flame sensor wont get a reading and wont fire.
Surely that is not the case. While UK have polarised sockets most EU does not, so any devices with the plug must be designed in such a way to be safe either way they are connected, unless they are hardwired and manual specify how to connect it.
Not true, even a non-contact pen proves otherwise.
Yes it does as any fuses or similar protection will be in the L path within the equipment.
For equipment that has no connection to earth, why might reverse polarity be an issue? What I mean is, if a fuse isn't for earth fault protection, it would be for overcurrent protection: opening the circuit anywhere would deal with the overcurrent problem.
What further problems could occur if the N was open rather than the L? (Not disputing what you're saying BTW, just asking). The only equipment like this that I can think of that would be a problem reverse polarity would be class II ES lampholders.
It will depend on where the reverse polarity occurs.
If it’s at the supply end for instance the cable will remain live as will the item.
How will the fuse or driver know which way round its connected though, there wont be any earth present so its just two live wires with 230V across them, both are live with respect to each other 50 times a second, there isn't any live or neutral as far as the driver is concerned.
Understood, but in the context of post #8 we're talking about reversing the wiring at the equipment rather than the upstream circuit
I'm not too sure how those pens work but I assume you are creating a path to earth for it when you hold it, much like a neon screwdriver. Live and neutral are both at 230V relative to each other, its only because one side is tied to earth that it becomes the neutral, you could tie the other side of the supply to earth instead and that would then become the neutral.
I sense cross purposes here. Post 8 is actually more specific than it appears at first glance.
But in terms of cross polarity equipment with no earth, integral switching could make it unsafe.
A integral fuse one the ‘return’ could leave things more dangerous for anyone (unwisely) working on it live.
In most cases, if equipment isn’t marked it isn’t gear I want to be using anyway!
The pen would still only work on the L side whether that’s the chassis or not.
Maybe a socket tester would be a better example
Even a class 2 enclosure circuit could rely on the polarity having to be correct as a fault could make the o/p L instead of N it would have to be a pretty crap circuit for that to happen though.
Let’s just say that some appliances, it doesn’t matter…. On others it does…. For whatever reason.
Radios tvs etc with a figure 8 cable plug can be put in either way… so doesn’t matter there….
Other things, if marked L and N, must be for a reason.
The LED driver in the OP is unmarked, so either way would be possible.
I seem to think the Ring video doorbells are the same? ELV, but still AC from a transformer.
Only 2 connections, and no markings whatsoever.
HappyHippyDad
Supporter
Gloucestershire
Polarity on this led driver
HappyHippyDad,
brianmoooore,
