- May 8, 2023
- 5
- 4
- 33
- United Kingdom
- Trainee Electrician
Hi guys, need a bit of advice,
EICR was completed on the property which needed a new consumer unit and a few other bits like broken sockets and damage pendants.
What’s the best way to address this with a certificate? Is it an eic stating the consumer unit has been changed and other work carried out as to the last eicr?
