- Apr 22, 2024
- 4
- 1
- 3
- United Kingdom
- DIY or Homeowner (Perhaps seeking pro advice, or an electrician)
Hi all,
I'm in the UK and have recently had a ducted extractor fan Mixflo 200W with timer fitted. The fan comes on with the pull cord and runs for 2 minutes after the light is switched off. So far so good.
Some family members don't like the humming and to be fair most of the time the fan doesn't need to run.
Question: I'm considering fitting an additional wireless switch and receiver so that I can override the fan, essentially stop it from coming on when it's not wanted.
Am I ok with something like this for the switch Ener-J WS1050X Eco 1G Wireless Kinetic Switch - https://lamplec.co.uk/ProductDetails/?code=WS1050X and this for the receiver Ener-J WS1055X Eco Non Dimmable 500W RF Receiver - https://lamplec.co.uk/ProductDetails/?code=WS1055X or is there anything I should be aware of?
I've in the past fitted one of these switches to a light that was already on a wired switch and that all worked great.
Any advice appreciated.
Cheers
Stefan
Cheers
Stefan
- TL;DR
- Can I fit a wireless switch to an existing extractor fan that activates on a light pull?
