S srwyate Apr 18, 2023 #1 replaced sensor and no change oil pressure test came back normal thinking wiring?
DPG ~ Esteemed Arms Supporter Patron Dec 9, 2008 13,496 18,280 3,557,381 S Yorkshire If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at? United Kingdom What type of forum member are you? Other If other, please explain C&G 17th edition regs C&G 2382-18 (18th edition regs) C&G 2394 Inspection & Test C&G PAT 2 x BPEC electrical courses/exams Apr 18, 2023 #2 Welcome to the forum. .. .. ..
