J
Josh95
If 4 sockets have been added to an existing ring & 2 lights have been added to an existing lighting circuit.
What certificate should be issued ?
As long as there aren’t any new circuits installed from the consumer unit then a minor works certificate for each circuit altered should suffice.
Minor Works Cert.
Reactions: DPG
Why would a special location make any difference ?
Special location would mean it being notifiable work to LABC either direct or through CPS
But it has no effect on the certification required. 2 minor works or 1 EIC, as Murdoch says.
  • Agree
Reactions: DPG and Rosco
Are you an Electrician? yes, then you should know the answer, A MNWC is issued for an alteration to an existing circuit, which sound's as though that's the one you require.
Reactions: DPG
Minor works x 2
Or
1 x eic
Why not use 1 of these
http://www.wmjoiner.co.uk/download/4 - Minor Works Certificate 17th Edition BS7671.pdf
Can't see why you would issue an EIC for alterations of an existing circuit.
Appendix G OSG
G2.1 The EIC is intended to be issued where more significant work is undertaken:
A complete rewire
Rewire of an existing installation
Replacement of a CU
Addition of a new circuit from the DB or CU
G2.2
MEIWC
A MEIWC is intended to be issued for an addition or alteration to an existing circuit
Adding a lighting point
Adding sockets to an existing RFC
Rerouting an existing circuit
Replacing an existing shower
Replacing circuit breakers with RCBOs where there is a difference of over current type.e,g, replacing type C for type B.
Reactions: DPG
Appendix G OSG
A complete rewire
Replacement of a CU
G2.2
MEIWC
That's 'cos those pesky schemes, have cotton on to the fact, that when using their on-line certification, if you've modified more than circuit, you'll need to complete more than one of their MEIWC (each cert' has only space for one circuit).
So the cost conscious amongst us, will then use an EIC, completing details for the necessary circuits, and adding 'Not Worked On' for the remainder.
Clever them schemes :)
Mind you, if was just two circuits or possibly 3, I'd submit 3 separate on-line MEIWC's and too hell with the cost.
You can get MEIWC for up to 3 circuits
Yep I know Pete, but the (Certsure & others I suspect) on-line MEIWC has only detail for one circuit.
So don't do it on line.
Reactions: DPG
Appendix G OSG
A complete rewire
Replacement of a CU
G2.2
MEIWC
I know the difference fyi
I'm on a job at the moment where I'm making changes to 8 circuits.... I'm not doing 8 minor works
Your choice.
Tyesoft easy cert is the same only one circuit
Not anymore, they have now added a multiple minor works for up 5 circuits
That’s good is there a software update or does it update automatically
Click on Help and check for updates.
An up to date Customer Care Package would be required
  • Useful
Reactions: Rosco
Additional sockets & lighting.
Josh95,
