steve100
I am trying to get my head around the Adiabatic equation and was hoping that someone could check my understanding?
I know the equation is S = √I² x t/k
S = the CSA of the CPC
I = the PFC which is calculated from Uo/Zs
t = now this is where I get a little confused, my understanding is that you use the PFC to find the disconnection time from the time curve tables in BS7671 and this is used in the equation, is this correct? I also read somewhere that the PFC must be higher than the current required to disconnect the protective device, is this correct? Is this part of the equation process, as I thought this was established through meeting the required Zs values in the regs?
k = is taken from the tables in the regs
I would really appreciate it if someone would help me and maybe give me an example?
Steve
Steve
