- Apr 29, 2010
- 1,695
- 420
- 101,758
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
Morning Chaps :smile5:
Will be wiring up some heating controls today and may need some advice along the way please.
This is always up until now something I have always passed on to someone else, not anymore time to bite the bullet.....
This is the spec:
combi boiler (not sure on make/model just yet)
zone valve + programmable stat just to be used on basic mode not programmed (Honeywell CM700) = zone 1 heating
zone valve + analoge stat (Honeywell T6063B) = zone 2 heating
2 channel programmer (Horstmann C27)
Everything coming back to a wiring centre
Been looking through the schematics (s plan, but just replacing the cylinder stat with room stat) and follow it fine.
Couple of questions I have already:
1/ With programable stat receiver, just trying to verify the connections on there: obviously perm L, N, E fine..... looks like brown to zone valve goes into B, but where does the switched live from the Horstmann programmer go? Sure it's A? The I reason ask is that looking in the Honeywell paperwork it has 2 different schematics one for zone valve (no obvious switched live in shown, link between A and perm L) and one for combi boiler showing different connections ?
2/ The other connection I will need to work out is where abouts my oranges from the zone valves go in the boiler. Lr if it's a Worcester ?
3/ And would I be correct in thinking all I will need at the boiler position is a L,N,E and live return from zone valve? Or have missed anything else ?
Any other pointers would appreciated.
Many Thanks,
Sy
This is the spec:
Many Thanks,
Sy
