IAmSparkytus!
485
354
101,238
Newcastle Upon Tyne
United Kingdom
Hello
As the title says, wondering what works best for everyone when pulling cables in along a decent length of cable basket where you’re not able to run the cables along the floor and lift and drop them into place?
thanks
Hello
thanks
Have seen videos of people using RC cars/trucks!
RC car would work on tray but not on basket.
Reactions: Resu
Rod the length and draw rope?
I made myself a "bobble" for my rods - bit of dowel, drilled, edges rounded, bit of 4mm stud and nuts. That was for some 3 section trunking where the dividers were "a bit out of shape". The idea was that it might "ride up the step" instead of dropping to the next section down where the dividers weren't lined up.
I figured it would be easier only taking every 4th lid off - it's a standard 10x1m set. It nearly worked :rolleyes:
For basket I've found rods will often just push along provided you keep them flat and straight where you are feeding them - but that does depend on the basket having been fitted well without steps.
Otherwise, something thicker like 20mm conduit can do the trick.
A length of PVC conduit with an empty water bottle taped to the front.
Coke bottle is usually stronger and more rounded than a water bottle
Whisky’s even stronger
Newcastle Upon Tyne
United Kingdom
Best method for pulling cables along cable basket
IAmSparkytus!,
IAmSparkytus!,
