Mar 11, 2010
688
77
1,203
Midlands
Electrical Engineer (Qualified)
HI all,
got 6 flat to wire soon but wondering on what if any sort of fire alarm protection to do
basically its three rows of flats with one upstairs and one down, but three separate doors so it looks like three terrace houses , you open the door and immediately to your right is the door to the bottom flat, then straight up stairs and immediately to the right is the door to the top flat.
at the end of the flats is a leanto for the boiler and mains etc.
having trouble to see what to do about the smoke alarm system and what is best to put in, alo where would i put the panel??
another question have is it ok to run the concentric cable in the loft of two of the top flats to feed the mains to the other flats, also the aerials and phones if needed?
Cheers
Grand
Is this a new build.
If you are considering a Part 1 system you may have latter issues with the routine testing of it, is it going to be landlord controlled. You then have to decide on the Category of system and its extent through the property, for example will it just cover escape routes with sounders in the dwellings along with separate Part 6 systems in the dwellings. Are these private individual dwellings because a Part 1 system throughout will give rise to nuisance activation and frequent evacuation with the long term affect that people will eventually ignore it. Building structure and compartmentation will also be a factor, there is a lot to consider.
Some worrying questions here imo, do you think you have the knowledge & experience to be undertaking this job?
You cant just put in "what smokes" you think you need! You need properly designed plans/drawings to current 5389 standards.
Why are you using concentric cable? Woudnt swa be a better option.
You shouldn't really run the cables through the lofts of other flats. If it was me I would be looking at having a couple of ducts to each....one for the mains and another for the BT, TV etc. With regards to the fire alarm I would of thought it would be three seperate panels (one for each section) with 3 zones on each communal, and a zone each for the two flats that share the same communal area. Using addressable panels and cause and effect programming you could use an addressable input to trigger the sounders in each of the 3 sections if a fire is detected in the mains room/switch room. I would get someone in to do the design and commissioning and you just carry out the install side of things....This is what I generally do. Where abouts in the country are you? I know some one who's **** hot and reasonably priced.
Part 1 systems in private, separate dwellings is not a great idea. Sheltered housing which is managed 24hr maybe.
Part 1 systems would require regular testing and keeping log books /test records up to date so maybe not suitable for private dwellings unless it's going to be regularly maintained which I doubt
Yes I asked this in #4 because there is not enough info for the nature of the premises.
I agee with murdoch , you need some one to plan the whole system
for you if new build then is should on the plans .
Reactions: Octopus
Will they be commisioning the system for you or will you be doing it yourself.?
At this stage the is no point in getting anyone to design or start an install.
First Building control and local fire officer are required to conduct their fire risk assessment. The will decide on a full fire system or an AOV system, or even both. The criteria will be the height of the building, construction material. At this stage your only design will be Part 6 in each dwelling.
they come round tell you what you need , i wire it and use there stuff, they put a cost of commissioning but its up to you if you want them or not, last two times ive just used them
Midlands
fire alarm system in flats??
Security Alarms, Door Entry and CCTV (Public)
grandfortune,
grandfortune,
