L
Leader
I can't for the life of me work out how to get my probes into the "test ports". What am I missing?
Take the black tip off, if you are using double pole voltage tester? or is it MFT?
cobblers. stick an inch of solid strand 1.5mm bare copper in your croc clip.Neither my voltage tester nor MFT probes will fit. Obviously I can't possible take the finger guards off because then they won't be GS38 compliant and I'm not a rule breaker...
bvut if they made them bigger some muppet would stick something in, get a shock, then sue.
Like "an inch of solid strand 1.5mm bare copper in your croc clip."![]()
A fine end to your story ...What am I missing?
