had a call out, old lady said some sockets had stopped working since a power failure. so i went round, checked fuse, checked the board all ok, started testing at sockets with a plug in tester and it was showing up some ok and some had no neutral, then on about the 2nd or 3rd one with no neutral as i plugged it in it started flickering and the other half of the kitchen sudeenly powered up(washer/drier/microwave etc all beeped). so i knocked the power off, inspected the back of the socket neutrals slack as **** and had been arcing which had got hot and made the insulation brittle about 1.5" up, so i cleaned them up, fitted some sleeving and put the socket back on. then tested the rest of the radial and it was all fine.
now heres the problem, what sort of paperwork do i do for this? all i've done is correctly refit a double socket, i havent installed any cables. it can either go two ways, open a can of worms (no RCD, no bonding, house basically needs a rewire) and start doing paperwork, or just forget it as the job was 5 minutes away and took 15 minutes. and i havent done either yet, i said i'd be in touch with an invoice...
so what would you do?
