Y
yellowvanman
Looking at my 1st install, electrically piece of cake! Mechanically/structurally I'm a bit nervous.
Customer wants an array on a barn roof.
Whole structure is made of pre-formed concrete pillars, joists etc. Newish roof is metal panels which have been screwed onto wooden battens that I guess have been secured to the concrete cross members etc.
Wooden battens look to be only 50mm thick, 100mm wide, and these are spaced about 1.5m apart (from eaves to ridge).
Questions:
1) What is the best mounting system for this, bearing in mind I've only got about 50mm of wood to screw into?
2) With the joists 1.5m apart. The Schuco installation manual suggests that brackets are at 1/4 & 3/4 positions on the long side of the panels. Does it matter if this requirement is not met?
Got some photos if the description above is no good!
Questions:
