H
Harry Worth
Mate asked me to look at his immersion heater that had stopped working. The tank has two elements - labelled 'On Peak' and 'Off peak'. It is the off peak one which has failed. No breakers tripped but the neon on one of the switches (off peak) is out. I've measured around the circuit - no power anywhere so I took the front off the CU to check there. There are two circuits - one supplying the immersion - no power on the input to that circuit so no power to the storage heaters either. The meter is outside his flat - How does the economy meter work. It seems as if there are two supplies entering the CU - One of which is dead. Is it possible for this to be down to a fault with the meter or am I woofing up completely the wrong bush?
