Connected up a showermate pump for a friend this evening. A plumber friend installed the pump a few months ago into the system, I just put a supply to it
Wired a FCU spur from a RFC socket in landing. Tested the circuit. All is good.
Energise the circuit. All good.
Open the tap to enable the point to run, RCD trips.
I knew it had to be something with tbr pump so I did a continuity test on it. There is continuity between neutral and earth. The cable is a pre wired flex.
Am I missing something, it's been a very long day....
