- Sep 13, 2016
- 598
- 53
- 1,203
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
Testing SWA 16mm sub main to a garage, getting reading of 66 ohms between R1+R2 and a IR resistance of between 4-5 M Ohms anyone explain how? The RCD is all fine and not tripping just testing
L
All I can think of is loose connection one end, high resistance joint, or SWA corroded
L
