to the OP as long as the power is removed and battery is disconnected there should be no problem removing the system. as a locksmith I installed a lot of alarm systems and no 2 installs were alike.
the level of security is what determines the complexity of it.
but the best alarm system is the one that's difficult or impossible to detect.
all too often some alarm companies will put up their brag signs in the yard advertising there is an active alarm system there.
to a savvy intruder that just tells them the list of things to look for.
Be careful to not rip your phone line out at the same time ‍♂️
Reactions: ruston
Just disconnect it at the fcu after removing the fuse (and also turned off st the board) and remove the alarm and it should be fine. If it's been off for any period the battery will be dead anyway
Rip the heed off it :confused::cool::eek::eek::eek::D:D:D:D:fist::sweatdrops:
Removing a circuit with security alarm - help?
DIY Electrical Advice
BrennaBoy,
MG201,
