B
Byron Caldwell
Hi all.
Please can someone help me with a possible cause and solution. I installed a Solis 4.6kw 4G grid tied inverter with the CT for anti islanding. But the inverter says limited by EPM and sometimes by DRM and only generates like 60W. But I know the load is much much higher than that so the limitation does not make sence. And the CT is the right way around
do you have the correct uk g81 selected.
sorry G83 for single domestic dwellings.
I am actually based in South Africa and I think it is set to G99. I left it like that cause I think it gets preset?
What is weird is that I see on the monitoring app that it did spike 3 times but only for a few seconds then goes back to 62Watt. Obvious reason would be loose connection in the CT but I doubt cause I have double checked.
apologies wrong country. i think just on powering up they output something like your seeing. perhaps you should force a reset and stsrt the set up procedure again. aftrr that i am lost as only worked on one of their ranges before. ok.
Solis 4.6kw 4G limitation issue
Byron Caldwell,
Byron Caldwell,
