danesol
I know of 1 other system that is on the same sub station looks in the region of a 2kWh, i have long had issue with halogens popping way to soon and LED transformers not lasting long..
Well if you do have a voltage issue at some point, check with your neighbours as if they are also experiencing high wear & tear - as you may find that approaching a DNO in bulk, is a lot lot easier with a more favourable result, especially if they have to fork out for replacements like they did with me.
