Jan 25, 2016
74
Nottingham
Hi,
I only have 1 socket in one my rooms but would like to install 2 more double sockets, the kitchen backs onto the room and i thinking about spurring of the one of the sockets in the kitchen, i was going to install fused spur (fused 13A) then off the load side install 2 double sockets. Is this ok? meet current regs?
All help appreciated
Is it on a RFC ?, you can spur off 1 per point if so. (make it a double)
FCU makes it legit OP so knock yourself out, however, I'd probably try and get a second cable in and extend the RFC.
Yes but the op is putting a 13 amp fuse in to protect the 2 sockets although not ideal i can t see a problem doing it this way as long as the sockets are to be use for low current items .
Could i extend one of the cables using 30amp connector blocks in the back box of the existing socket, then i could make the 2 new sockets part of the ring?
any thoughts on this?
Nothing to say you couldn't, not ideal though, if connections are done correctly I would use wagos instead of connector block, and change the back box to a 47mm give some room
call me sceptical but electricity is the same in the home as in an industrial application ..... as are most of the regs ...
just a thought, does it have a separate kitchen ring? don't like the idea of 2 sockets in one room fed off the kitchen ring and the other fed off the house ring, I know its not against regs but always the potential for some numpty to attempt diy in the future.
Reactions: DPG and Pete999
Nothing usual about this at all. Very common imho
Reactions: hightower
It sometimes can't be avoided, and to be fair anybody working on the circuit(s) in future should know what they are doing anyway, true?
no doubt about it all! but should know what they are doing and actually knowing what they are doing are 2 different things, like ive said its not against regs and yes it will happen in lots of places just not something I like to do.
Could spur one socket from the socket in the kitchen perhaps and another from the existing socket in the room?
Then there would be no need for an FCU.
Nottingham
Spurring off a ring
richo106,
stevethesparks,
