Discuss Spurring off a ring in the UK Electrical Forum area at ElectriciansForums.net
Hi,
I only have 1 socket in one my rooms but would like to install 2 more double sockets, the kitchen backs onto the room and i thinking about spurring of the one of the sockets in the kitchen, i was going to install fused spur (fused 13A) then off the load side install 2 double sockets. Is this ok? meet current regs?
All help appreciated
Could i extend one of the cables using 30amp connector blocks in the back box of the existing socket, then i could make the 2 new sockets part of the ring?
any thoughts on this?
Nothing to say you couldn't, not ideal though, if connections are done correctly I would use wagos instead of connector block, and change the back box to a 47mm give some room
just a thought, does it have a separate kitchen ring? don't like the idea of 2 sockets in one room fed off the kitchen ring and the other fed off the house ring, I know its not against regs but always the potential for some numpty to attempt diy in the future.
Nothing usual about this at all. Very common imho
It sometimes can't be avoided, and to be fair anybody working on the circuit(s) in future should know what they are doing anyway, true?
no doubt about it all! but should know what they are doing and actually knowing what they are doing are 2 different things, like ive said its not against regs and yes it will happen in lots of places just not something I like to do.
Reply to Spurring off a ring in the UK Electrical Forum area at ElectriciansForums.net
Hi guys, newbie posting! Does the following sound ok... Existing circuit: SOCKET on a ring -> spur to SWITCHED 3A FCU -> SWITCH -> hardwired FAN...
i have just started my course as a trainee electrician...some advice on the following will be appreciated: I have a spare 16 and 32A MCB (RCD...
Hi, if getting back to the CU is not an option, instead of spurring off a socket via a Sfs putting the rating down to 13a. Could you spur off the...
If someone made a request to you, to install a new double socket that would be supplying power to a tumble dryer along a circuit that does not go...
DIY'er question: I have a singe switched fused spur above my kitchen counter, providing power to an undercounter fridge socket beneath it. The...
