As all the ole boys (no insult intended) have mentioned, a non contact volt stick should never be used to confirm voltage nor for safe isolation/ dead test its merely an indication. Ive had it before where i can pick up EMFs from other sources with a volt stick giving me false indications! Especially around flourescent lights and particularly in substations, walk into some subs with a volt stick on and they go mad! Drummond test lamps are actually a pre-requisite for working with our local DNO, outside of that I use my fluke t130.
My new one turned up today so I am retiring the old one.
My bathroom fitter mate rang me up yesterday all confused as he didn’t know whether a circuit was live or not as his volt stick kept lighting up when he put it down on the loft insulation:rolleyes:
Try one of these.
I have a Martindale TEC 100 that went through the wash. removed battery and dryed it out and it still works!!
Currently waiting on a new one as although I've tested it around the house I don't trust it. (not that you should trust them. but good for an indication)
My old Fluke volt stick which had no on/off button, the white end bit broke off.
I used superglue to stick it back on and wrapped white electrical tape around it.
I then found, if I walked into a room with live circuits, it would light up.
Soon as I removed the tape, it worked correctly.
Reactions: HappyHippyDad
Does no one just lick the end of their finger and gingerly and quickly touch the end of the supposedly live cable?
The only proof you need if you are off the floor is a known earth !
( If your volt stick lights for that , your probably sitting on a live wire in the attic ) .... all results near masses of wiring
MUST be taken with a pinch of salt ..
(capacitive coupling will Light LED lamps and you volt stick !)
( Proving unit for high impedance tester =Waste of money)
Pete999
Supporter
Northampton
Retired Electrician
Business Name
None
Non contact voltage pen proving unit
Pete999,
Squid,
