W
Wilko
For the Electricians reading this thread - the installation instruction says the fan normally requires a 3A fuse unless it’s connected with a 6A breaker. Top marks for common sense
Is the fan in the shower (zone 1) if so it should be 12 volthey, so im a DIYer and learn most stuff from youtube tutorials. At the moment am doing a bathroom renewal, and want to replace the extractor fan for a stronger one. I've a very basic understanding of house wiring and electricity, however i think i could do something straightforward like replacing an extractor fan, if i know follow the instructions.
My worries are getting the right power rating fan, so could you guys give me some advice on this?
cobblers. a 230V fan is allowed as long as it's IP44 or better. would you insist on a 12V shower unit in zone 1?Is the fan in the shower (zone 1) if so it should be 12 volt
here's a some visuals bathroom - https://Upload the image directly to the thread.com/a/RQkEV7c
thanks}
Fair comment never thought of it like thatcobblers. a 230V fan is allowed as long as it's IP44 or better. would you insist on a 12V shower unit in zone 1?
there speaks the prophet of doom^^^^^..
Makes sense but now you mention it a 12 V shower does sound safecobblers. a 230V fan is allowed as long as it's IP44 or better. would you insist on a 12V shower unit in zone 1?
try heating the water with 12V. the amperage would be around 800A. some serious cable size there.Makes sense but now you mention it a 12 V shower does sound safe
hi, thanks for the useful info, but i'm interested in getting a manual fan with a higher flow rate. my bathroom has no window and people take long showers, the current fan almost never speeds up and i have to remove the front plate cover every time just to temporarily increase the speed.![]()
the heater was removed and will be replaced.don't give up the day job as that video clip shows nothing.
back to my original post - have you checked the "output" from the vent outside?
Also if you don't have any heating is a shower room the steam will be worse...........
i'll try cleaning out the vent/duct and the outside cover, before replacing fanthe very LAST THING that shower room needs is a manual fan.
Higher through put and longer timer ......
it works, but i'd rather a replace it with a higher power oneIs the 'old' fan broken (not working)?
