T
Thedailyb
Hello,
I am planning on installing two industrial fans in my pole barn. Both fans would be controlled by the same switch. I plan on having an electrician/inspector check the work before it is plugged into panel but I am hoping to save money and do most of the work myself...
Here are some facts that might help you understand:
-Here is a link to the wiring diagram from the manufacturer of the fans and the switch: https://www.canarm.com/assets/product/documents/M0062-CNFRMC5-060607.pdf
-I have a 100 amp subpanel in barn with lots of room left over.
-I live in Michigan in case the code for my questions might depend on my location.
-The fan shows five wires coming from it (including the ground).
Here are my questions (please bear with me as I am not an electrician):
-Do I connect the fans together and then run a connection to the switch? Or would I run separate connections from each fan to the switch? The second choice would require more wiring.
-What type of wire would I use to connect the fans together (via the five wires)? I live in Michigan if that impacts the code. Could I use a couple 12/2 romex and mark the wires carefully? (This would leave me with an extra ground wire that would not be used.). Or should I use something thinner so that it is cheaper and easier to fit into junction boxes?
-I am planning on using a 20amp breaker in the panel box? Is this what you’d recommend?
Thanks in advance for any help that you could provide!
Hello,
@Thedailyb welcome to the forum and yes you can tie both fans together and run 12/3 Romex to your light switch. You stated that you had 2 industrial fans and one has 5 wires what about the other fan. I need to know the HP, the voltage because they could be multi tap fans, also I need to know are they single phase or 3 phase, then the full load current before I can advise you any more till we get the proper info. Your link is not working
That link is to a 120v single phase fan speed controller hence all the wires from the fan. It is only for the speed controller with no info on the fan motor power.
Reactions: Megawatt
Thanks for the info Westward I guess we will see if he responds
It is also reversible as well as speed controller.
When he said industrial fan is what got my attention the most. You and I both that they can be multi tapped and with the speed controller and reversible to. Thanks for the info
Hello,
I told you yesterday that you need 12/2 with a ground romex and you need to use that ground wire on both ends
Two Industrial Ceiling Fans on One Switch
Thedailyb,
Megawatt,
