- Aug 12, 2017
- 14,334
- 20,731
- 3,557,381
- 51
- United Kingdom
It doesn't fill you with confidence that a trainee couldn't work this out. (no offence, its just how you have been taught)
The OP gives no mention of the fitting being ES, but through dead testing with a simple multimeter you can work out which black is neutral and which is the switched live (and as others have mentioned, should have been identified with tape or sleeving) by taking the switch off.
Ive never known it as a "3 plate" system, just called a "loop in"
