IAmSparkytus!
485
354
101,238
Newcastle Upon Tyne
Morning all!
Just been having a quick flick through some threads and enjoying all the good advice being offered to many people on a variety of topics!
While flicking I've also noticed info on earthing nuts and wiska gland plates which have blown my mind as it seems I'm currently still stuck in the dark ages using banjos for all SWA installations.
To add to this I've only not long ago started using wagos instead of connector block...
This has made me want to ask whether there are any other really simple (probably second nature now to you all) materials/accessories and tools which would make commercial fit outs easier and simpler?
Thanks all, have a good day!
One recent discovery/conversion for me is Flexishield cable.
An obvious use-case is for cables in walls where you don't want RCD protection, but you want something a lot easier to wrangle than SWA. Another is for cables clipped on walls where you might have rats, etc, and so PVC T&E or rubber is not good, as they don't seem to like Flexishield. They even make a cat-urine flavoured version of it for really problematic areas (farms, etc)
But the normal stuff is good for many industrial/commercial applications as it looks fairly neat if clipped to walls and is stiff-ish so stays in place. It is similar to FP cable but really rated for nail penetration RCD trip action.
Great post - I look forward to seeing what else emerges that I've never heard of!
Thanks particularly for mentioning earthing nuts - I've also been using banjo connectors....!
I recently learned of Quickwire connectors which are awesome for rewiring lighting ridiculously quickly, or cable repairs, especially if lots of lights are on the same switched circuit. I has a room full of downlighters in a suspended ceiling and every single one just had single insulated cables looping in and out. I was amazed to be putting steps away about about half an hour having rewired the room.
Quinetic wireless light switches were another recent revelation - no battery in the switch, works on kinetic energy. More for domestic really though.
Swiftnut when your doing threaded bar after threaded bar after threaded bar......Spins it up the rod in no time, saves getting rsi while building trapezes!
And CMP island glands for easy testing of sub main earth after sub main earth after sub main
earth......isolates gland from housing and easy to disconnect the lemon and lime!
Few other things to mention, for SWA the "Tauras STORM" glands are really good, as well as actually being IP68 rated for situations where a lot of water is likely.
Recent tools that I value are a torque screwdriver. I know a lot of experienced folk can get away without them, but to me its a bit like a car. You can do a lot of jobs without a torque wrench, but you would not consider a cylinder head change without it. Same for electrics, many jobs a screwdriver and Mk 1 hand is perfectly fine, but for a CU, control panel, etc, going over it with a torque driver to the specified values is much the same.
Other great tool (to be used with care) is a impact driver:
Along with the Armeg hole saws:
Though in retrospect I probably would get the quieter 'hydraulic' impact driver instead as I don't need full power most of the time and would rather have less noise.
Reactions: i=p/u and timhoward
This sort of kit:
Reactions: Timbo
Am curious about the Armeg "impact" holesaws. In what way do they differ from standard holesaws?.
On a separate note, I recently was alerted by a poster here to a multitool blade for cutting plaster and brick. The pictures of the cutout box looked really neat. That's the next buy on my list
Have been thinking about getting a torque screwdriver recently. Can you recommend one? Are they expensive?
I'm a nightmare for losing tools so tend to avoid screwdriver sets with interchangeable heads!
Im also interested to know, and you'll probably be able to tell me, whether the torque drivers make things more or less tight than someone would tend to make things with a standard screwdriver?
You may already have one, but the endoscope cameras for 30 to 50 euro are worth their weight in gold for domestic work. Being able to see what's above a ceiling or under a floor, in a stud wall, BEFORE drilling gives, great piece of mind.
They look the dogs proverbials! How much do they cost? Do they only connect 2 twin and earths or can they connect say 2 twin and earths along with a flex to a light fitting for example? And do they make them for 3 core and earth?
They are brilliant just a little tad expensive to me. But no doubt I'd lift one if heading to metal munch
I've got a few of these, they're best used on sheet metal really. Fuse boards, metal trunking etc. They're only maybes 20mm deep, have a flared end which prevents you from pushing the holesaw further inside after the hole has been drilled, and they have a spring which shoots the metal back out to stop it getting clogged up.
Can use them on other materials if you need to avoid hitting cables etc but plastic and wood will get stuck inside like a standard holesaw.
I like the look of this cable , particularly the rodent retardent version, could well be something that I could use . Thank you pc 1966 for the heads up.
We love your input pc66, happy Saturday man.
They look the dogs proverbials! - They are.
How much do they cost? - See link below.
Do they only connect 2 twin and earths - Up to 4, see link below.
or can they connect say 2 twin and earths along with a flex to a light fitting for example? - See link below.
And do they make them for 3 core and earth? - Not yet.
See responses inserted above.
The Wiha one is very good, goes from 1nm-5nm I find its handy for double checking everything is good, I do all connections with just a normal screwdriver then nip them up with the torque screwdriver that way no connection is missed.
I must admit I don't own a torque screwdriver , but do keep one eye on ebay for one going cheap.
I have borrowed one to use but never felt like parting with £100 just for one
Might be worth keeping an eye on Amazon warehouse deals. Quality stuff isn't usually discounted too much, but if it sits for a while there can be some decent bargains.
I'm looking at getting one of these. I'm considering the "depstech wifi camera". (The Ferret Camera looks awesome but can't justify that money really.)
I bought a cheap one (35 ish from memory at an Elex some years ago from one of the small tool suppliers there - Felo - a German make, with some long insulated bits, but they are getting a bit worn - It seems to take standard 1/4 hex bits, but the trouble is now that no-one seems to do insulated bits that fit it. (The Wiha slim torque are close but not close enough annoyingly).
Only does up to 3Nm though - some of the makes seem to require ridiculously high figures that anyone would struggle to achieve without the mcb breaking apart....
I've started using one of these recently, initially for CU terminals but find it handy for umpteen jobs. Adjustable torque upto 5Nm too.
Do you find that the terminals are tighter now than what they used to be when you would tighten them with a normal driver?
So what do you in that instance?
Probably not TBH but tried tugging a few out without success!
Use the GO upto 5Nm then by hand. Some 7.5Nm but not seen many electrical equipment any higher that I can recall. Perhaps there would be if terminating to a 132kV network for example?
The Armeg hole saws don't appear to need as much torque to drive them, my Makita 10.8v drill or impact will quite happily cut a good number of hole before the battery needs charging
Reactions: LastManOnline
I think its just the speed, they are designed for higher speeds that the impact can deliver.
My impact rarely cuts in to impact mode when using the armeg or similar (Starrett) holesaws.
As other have already said, does the job well using the impact driver with 1/4" hex drive (just like the hex-shafted drill bits, easy to use if a touch less precise then traditional 3-jaw centring chuck).
But key thing is it won't go all the way through, so less risk of damage to stuff on the other side. Yes, you still need check it will clear stuff, and the risk of swarf or the spring-ejected disk have to be allowed for.
The resulting hols are quite clean, not as good as a hole punch (still have & use them), but better than I had anticipated from a hole saw.
This is the one I got, fairly easy to use but can't compare to any other VDE rated ones as only one i have.
I also have a metal 1/4" square drive 'screwdriver' style torque wrench for lower values, and both 1/4" and 3/8" drive toque wrenches going up to 25Nm (and 1/2" for 120Nm or something). While I have used them for electrical terminals I feel very uneasy as gripping a good solid connection on what could be live. Yes, I did my safe isolation procedure, but it still feels wrong not to be using insulated tools!
If I did more general sparky work I would pony up the several £100 to get insulated versions, as even if the terminals I am working on are dead, there is a risk of dropping the tool on to something live and high current leading to a nasty arc-flash incident.
I find for the lower torque terminals, say around 1.2Nm, it is not much tighter than my own hand-feel would go, but for the top end at 3nm (or more with the socket style wrench) it is higher than I would normally risk going, though that is the manufacturer's recommendation.
For the Hager/Schneider/Wylex stuff it was fine, for a cheap CPN brand MCB I had to play with it split the body as "recommended" torque.
Reactions: Dartlec
The Wera bits are insulated and 9mm hex, so you can use a socket but it has to be deep! Otherwise you just screw off a cm of plastic off the end of the bit.
Found out the hard way using my 1/4" hex driver to do 5Nm :(
Need to get this:
I've had occasions where I've had to hold an MCB together at the top while tightening, which isn't a great advertisement for the quality. The ideal would be to re-tighten a week later I suspect, but that's usually practically not an option - I do often tighten - energise, then re-tighten as the last thing before the cover goes back on though...
Reactions: pc1966
Been Youtube'ing today and found a page called Efixx. They were demonstrating the use of ferrules and a ferrule crimper. Not something I have ever thought about using before as I tend to use solid core conductors up to 4mm and pre-wired Klik flexes for lighting installs but definitely looks like they would be a handy addition to have on the van.
Anyone use these often and for what uses?
I wonder if all these sparks who now use impact drivers on consumer units check their terminations
Reactions: Dartlec
Maybes they've managed to find a DB manufacturer who recommended 110nM of torque for their breakers!
  • Funny
Reactions: DPG and timhoward
Reactions: timhoward
I use ferrules on almost all stranded cables... Both insulated and uninsulated ones.
Don't waste your money on these. I had a set a few years back. The 20 & 25 lost all their teeth in no time at all. The 32 now spins so is next to useless. The box is handy though!
I buy Reisser holesaws now whenever possible, they put most other brands in the shade.
Newcastle Upon Tyne
Handy Stuff for Commercial Installations
IAmSparkytus!,
nicebutdim,
