L
littlejohn
Hi folks
I have a lighting ring that occasionally stops working; when this happens, there is no power at any of the switches or ceiling roses. I've identified the feed wire, and it disappears inside the ceiling in the general direction of the consumer unit. There's no loose connections or anything obvious that I can find, and when this happens my pen tester says that the feed cable is dead.
What's odd is that sometimes, when I come in and switch the light on, the lights will come on for a fraction of a second and then shut off, and then stay dead. Last night I walked back in hours later and all the lights were on, until I switched them off and the next day they didn't work again.
Nothing trips in the consumer unit, ever - I'm about to lift the floorboards upstairs and follow the cable looking for breaks, but I had a thought - could this be caused by a faulty MCB in the consumer unit? It's quite old.
For what it's worth, I did not install this - so as far as I am aware it's professionally installed years many ago, and it's just recently that it's started to fail.
Any tips would be great
John
John
