ppelec100
290
72
103
London
Trainee Electrician
I’ve got some lug crimping tool called iwiss off Amazon and when crimping a 10mm cable into a lug I had to use 10mm on one side and 6mm on the other side of the crimper. Not sure how well it will work when it gets to bigger cables 😕.
Are there any decent lug crimpers at a reasonable price?
Reactions: ppelec100
I have a set of these for bigger sizes up to 50mm
They are ok but can be a pain in tight enclosures due to their size.
I also have the bigger set that do up to 150mm!
Also got a set of these that are better for tight spots!
Okay
Okay thanks for the link. I saw this on Amazon decent price. Has it done you well? Are the lugs accurate? (Not like my half 10mm half 6mm crimper)
Reactions: SparkySy
Yes mine are the SWA brand ones from Edmondsons years ago probably at least 10! They have been great, just sometimes in tight places they can be a pain as the crimp head is quite large and the handles need to open a reasonable distance, once the lug is in the handles aren't so much of a problem.
There is very little ware in the dies and they still make a good solid connection, done hundreds of lugs over the years!
Okay thanks mate, they seem about the same size as the ones I got.
No problem at all! 🙂
'Not enough characters'
I got one of these for the occasions I need to crimp lugs on larger cables:
It works quite well and handy to have the selection in the kit. However, you really need 3 or 4 hands, two to operate the handles and one or two to hold the crimp on the cable. The flare of the 'SWA brand' lugs helps a bit as you can partly close the tool and then push the held lug on to stiffer cable situations, but not ideal.
EDIT: I think this is the same basic tool as @SparkySy linked to.
@pc1966 has a point about needing 3 hands! I tend to get in a position where I can put one handle against something, the panel, wall or hip, thigh you know whatever it will stay against without slipping. This leaves a spare hand to get things lined up properly.
I have a hydraulic crimper I bought off either ebay or amazon for £30, comes with set of dies all way upto 120mm.
Bought it as I had to crimp some chunky cables for some new boards in a warehouse. and it has paid for itself many times over...
like others have said you could do with a third hand... so i have been known to hold the cable in the vice or clamp on a pop up work bench, even held the crimpers in the conduit bender before, a little piece of insulation tape is always handy to hold the lug in place prior to crimping...
Amazon crimpers in that price range top out at 70mm2, these days. I see a few around £67 that come with dies from 8-300mm2, but never believed they'd last too long.
I dont use it much so cant really say anything on long term quality other than its done what it needed to the dozen or so jobs i have used it.
I look at what i paid for tools a few years back and in some cases they have doubled. Inflation is one thing then mad shipping costs from far east.. everything is going up
I got a generic hydraulic set from Amazon/Ebay/Can't remember for about £60-70 maybe 5 years ago and it takes dies up to 300mm although I rarely need to go beyond 150mm. Not seen daily use or anywhere near that but still good and solid now. But as others have said, you need to be a real clever dick to use them - four hands are definitely better than two.
Reactions: nicebutdim
ppelec100
London
Trainee Electrician
Any decent lug crimpers for 10mm onwards?
Electrical Tools and Products
ppelec100,
Rockingit,
