- Dec 18, 2011
- 5,378
- 6,731
- 405,788
- United Kingdom
My customer has had a completely new supply installed to his garage. The DNO has not put a fuse in the cut out though. I'm guessing he needs to contact the DNO to discuss? I realise it would be very easy to pop a fuse in, but apart from this not being allowed, I also wouldn't know the size of the supply cable and therefore have no way of knowing which size fuse is safe.
Is it usual for the DNO to leave the fuse out?
Also, they have not put a meter in. I realise the meter is the domain of the electricity supplier, but I thought with a new supply the DNO fit one. Have I got this wrong? If so, does the customer simply choose a supplier and then they fit a meter? (Meaning the supplier has to enter the cut out)
lastly, it is PME. No earth cable has been terminated into the cutout. Is this something the DNO should have done (and perhaps left in an earth block). Not sure how else I am going to get the earth installed, without removing the fuse to get to the earth terminal.
Thanks all.
Thanks all.
