Discuss Own up , who done it.... in the UK Electrical Forum area at ElectriciansForums.net
No cpc continuity to metal box with plastic switch by the sounds of it. Only a C3 according to most though! I always like to fit nylon screws if the customer can’t or wont rewire I must admit.
Best guess is the metal back box came live ( possible pinched live ) nothing earthed so , inturn making the fixing screws 240v
240v zap in the morning will wake you up ready for anything
That's what I was thinking. I generally avoid poking screws of electrical accessories while wet and butt naked just out of the bath though.
I had an iffy light switch in my office where the screws were live through earth leakage from led lighting. A cheepo multimeter measured about 0.008mA but it still lit a volt test screw driver and sparked when earthed. It might have been a similar occurrence.
cheaper than the average shower, Boo-Boo.
It begs the question how Wickes or any of the other sheds for that matter vet the contractors they use, interestingly there is no mention of whether the electrical contractor was a scheme member or not
The picture on the article shows a shaver socket... so was that where the fault was?
It wouldn't have been me, this is more my style, I use these. They are a lot cheaper than that bigger version with that big square metal thing in the back.
You might want to read this Socket Outlets For Shavers: What Do You Need To Consider? - https://professional-electrician.com/technical/socket-outlets-shavers/
The bigger and more expensive version is manufactured for a reason
Given that a lot of homes no longer have a bath in the "bath" room should the regs embrace this and modify or include other types of wash room within the regs to avoid confusion or a bending of the intended meaning of particular regs
Looks like Yahoo lifted it from the Mirror, or vice versa - but in the Mirror's version:
the 52-year-old has admitted that the father of the electrician responsible for the work drove 50 miles from London to Sittingbourne, Kent to apologise for his "unqualified" son's work.
Which doesn't specify what counts as qualified though - would be interested to see if a Part P notification has been done..
Does also suggest that some of the issue was the existing installation - so maybe no RCD on that circuit, or cpc was used but not properly tested to see if it was connected.
However, if it really was the fixing screws, SparkyNinja, who's opinion I value, thinks that fixing screws aren't 'extraneous conductive parts' because of the small area exposed to touch, so that metal back boxes don't need to be earthed separately (though still good practise)
If it was a plastic back box, maybe the live ended up touching the screws because of the gap between tiles and the back box, since usually the screws are fully enclosed in plastic....
Which raises an interesting question - are tiles considered part of the 'enclosure' when they are thick and there is maybe 10mm gap between the front of the tiles accessory against the tiles and the front of the back box.
Edit:
This bit may be relevant (from the Mirror)
Despite this, when a second electrician came to fix the problem, he flagged multiple harmful issues - including the fact that live conductors were not made safe, and some were still live
Which could mean almost anything - but perhaps a circuit from the original room was just cut off and left in the wall, touching a back box? Or maybe that was just additional issues found when the installation was checked....
Would like this to be investigated by the HSE and a report issued, but no doubt Wickes will do anything possible to avoid that and it won't happen since there was no serious injury.
I think such a shock would unlikely be fatal as any contraction would remove them from the screw. Part P only applies to the area around the bath or shower since 2013.
For 99% of handymen , plumbers , DIYers and kitchen Fitters Part Pee has never applied
My post was not meant to be taken seriously!!!!
I posted that photo a while back in the dodgy trade pics. This was found in the bathroom at a retirement complex. A company had recently refurbished all the bathrooms in the complex and used non isolated shaver sockets in every bathroom, despite the red warning notice. The shower is just out of shot to the left.
I was there because the new plumbing in the bathroom of the apartment above was leaking, and water was coming out of the light fitting. I fitted a blank plate in place of the socket until someone could return and fit the correct item.
The regs don't refer to bathrooms, they refer to rooms containing a bath or shower.
Reply to Own up , who done it.... in the UK Electrical Forum area at ElectriciansForums.net
  • Locked
https://uk.yahoo.com/news/boy-10-dies-receiving-electric-093000771.html I must say in my 25 years on the job , hotel / hostel / b & b wiring is...
https://uk.yahoo.com/news/homeowner-quoted-45-k-for-extension-does-it-himself-from-you-tube-tutorials-112344400.html Fair play to him , wonder...
never ceases to amaze me just how impressive a battery fire is https://uk.yahoo.com/news/electric-bike-spews-jets-fire-112716839.html bet the...
