Dec 18, 2022
Uk
Other
It's a set of contacts to detect when the cover is removed.
Upon removal the smart meter advises the supply company that the meter has been tampered with.
Why do you have the cover off?
one cable came out several times and I tried to tighten it. what is going to happen now
The police will come running through the door any minute and you'll be taken for interrogation
Reactions: Ursanelec
Next time I'd phone the supplier to come and fix their meter, if a cable Is loose or coming out its a serious fire risk and requires professional attention.
A call to your energy supplier because you knocked the lid off the meter with the broom would be a good place to start.
Reactions: nicebutdim
Probably nothing, or else they might send someone round to check against electricity theft.
That cable is a very dangerous thing to be messing with, there is no isolation available at that point, and a misplaced screwdriver can lead to a large arc and serious risk of burns.
I opened this three weeks ago. but now I thought to ask.
One of the cables came out? Really?
Reactions: Dave OCD
To me, it still looks like there’s a transparent shield over the connections and a seal still in place… although I might be wrong. I don’t open meters to be that familiar with them.
Also, is that a smart meter that informs the DNO, or just a digital display
The question is, did you have to cut a seal to get the cover off? As that will be deemed as tampering.
If you say it was loose, sparking, etc… say you were worried it would start a fire and couldn’t wait for an engineer.
They might just give you a warning.
It's a Liberty 100 SMET 1, (gen 1 Smart) meter and would have had a sealed cover over the now exposed screw terminals, same as below.
Ok, it’s an older smart meter, but why does the OP have another sealed cover below the main cover? A bit pointless if the screws are exposed without outer cover.
the question is should I call them or wait for them to call me.
How sure are you that the wires are secure and safe? How did you realise that the connections were in doubt? Did you tighten the wires up yourself?
Any doubt then contact the supplier, but as above tell then you knocked the cover off accidentally. Don't tell then you removed it.
Reactions: pc1966 and James
It probably designed so the supply can be safely tested, but doesn't explain why there's provision for a seal on the inner cover.
As far as I know the inner seal is factory fitted to protect the calibration of the meter.
Old style dial meters also had a sealed screw behind the terminal cover preventing access to the inner workings.
I've also had this once, new barn conversion, new electric supply and smart meter. I was tidying up and the hand brush I was using knocked the outgoing live tail and it fell out of the meter! It had only been connected 20 minutes... I did call the energy supplier who sent the meter fitting company back. the lack of screw marks on the copper suggested the screws were never tightened.
Uk
Other
What is this?what is this. I marked it with a red circle in the pictures.
bombom,
OnlQQker,
