Discuss Help with a fuse box in the DIY Electrical Advice area at ElectriciansForums.net
Something odd about that MCB. All the Europa stuff I've come across has the blue logo that's on the other breakers. Fake?
Assuming the wiring is suitable for 32A, the one you should have fitted is EUB1RN.32/1C
No problem so if i fit the one you have stated it should be ok, thank you for your help much appreciated
The socket no longer has additional RCD protection which could lead to a dangerous situation. In the absence of an RCD you now need to confirm if fault protection is still provided.
Yes although the picture shows a type B the part number is correct.
Sorry to be a pain. The only place i can find that breaker is on Europa site but i cant order without an account. I can order from another place but the breaker is, see attached, I assume this will not do ?
Just try and go through to checkout pretty sure they aren't account restricted.
Reply to Help with a fuse box in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I'm trying to rewire an old plug. I've rewired a few in my time, but all have been with the post-2006 wire colours. I have this old welder...
Wallbox Fuse Box Lite Single Phase has anyone used one of these? I've installed one feeding a Pulsar Max, the Pulsar Max is set to 32Amp max. The...
I have a question which is confusing me and I cannot find a definitive answer and I hope someone can help. So I have a PC and Monitor and I have...
I’m planning a 240V welder circuit in a detached garage with a 100A sub panel. For the 160A or 180A output welders I’m looking at, the conductor...
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
