Nov 10, 2024
I have recently purchased a used three phase oven in good working order. The control circuit is 220 v and is supplied from one of the phases and a neutral direct from the mains board.
I have been advised that for, safety reasons a 440v/220v transformer would have to be installed instead.
Is this correct,?
there is only one contacter and 2 relays in the control circuit.
I can’t see anything wrong with the current setup.
A control transformer could be used and would be needed if a N was not available but is not a requirement if a N is available.
Reactions: westward10
Thank you James
Reactions: James
With anything like this, I would ask the person to point out the relevant legislation or reg. number in the wiring regulations.
Most arguments tend to stop at that point!
Thank you
Reactions: James
Control circuit supply
DIY Electrical Advice
Tangocharlie,
Tangocharlie,
