- Nov 10, 2024
- 3
- 2
- 3
- United Kingdom
- DIY or Homeowner (Perhaps seeking pro advice, or an electrician)
I have recently purchased a used three phase oven in good working order. The control circuit is 220 v and is supplied from one of the phases and a neutral direct from the mains board.
I have been advised that for, safety reasons a 440v/220v transformer would have to be installed instead.
Is this correct,?
there is only one contacter and 2 relays in the control circuit.
Is this correct,?
