ravipal
I want to replace a double pole light switch that I currently have in my hallway cupboard that controls my porch light. I want to replace this with a smart light switch so that I can control it remotely without having to open and hallway cupboard every time which is very inconvenient. The switch that I intend to purchase is the SONOFF T1UK1C which supports both Wifi and 433MHz RF remote control (in case Wifi does not work inside the cupboard).
Before going ahead I wanted to find out the correct wiring, so I am sure of what I am doing. I have attached here the current switch wiring and the wiring diagram from SONOFF for the smart switch:
The above is how the current switch is wired:
The above is the back of the intended smart switch and the recommended wiring diagram from SONOFF
My question is how do I take the current wiring to this SONOFF switch ?
Please do let me know if you need any more information or more clarify on the question.
Thanks in advance
Ravipal
Is that connected from a power circuit?
The smart switch does not have the fuse protection so it can't be used especially if it is a ring final circuit.
It is not suitable for use as a replacement for the fused switch you have currently.
it could be added after the fused switch as per the instructions above.
Reactions: brianmoooore
Thanks, if I add it after the fused switch, how do I connect the neutral and earth wires
Thanks, yes I think I will do this. Since there is no neutral out on the smart switch, where do I connect the neutral out to the light ? does it go together into the same N in ? and also the smart switch does not have an earth so can I connect earth out from the fused switch directly to the earth from the light ?
Yes the neutrals will be connected together in the same terminal and the earth joined in a 2screw earth connector just behind the switch.
How to replace double pole light switch with smart switch
DIY Electrical Advice
ravipal,
Tartansparkyman,
