Nice one mate yeah it was the one above this fluke t110 I think it’s called but that’s £81. I assume the one you linked would be good in the long run for electrics?I was going to suggest the Martindale VT12, but the Fluke from Amazon (if this one below is what you were thinking of) is 'only' £16 more and would be a better buy
You could go for a used t150Nice one mate yeah it was the one above this fluke t110 I think it’s called but that’s £81. I assume the one you linked would be good in the long run for electrics?
Is the t90 no good then? I’ll have a look at the others u mentionedYou could go for a used t150
There are a few t110 etc that are on bids.
Where did uYou could go for a used t150
the first link u posted to that t150 how legit and safe are they unless it’s knocked off or fake testers? They look too good to be true?You could go for a used t150
think ill just get the t90 for nowBeware getting stuff on eBay originating abroad as VAT and duty can bump the price a lot higher
good shout thank u mateTry here, they have plenty of options at better prices than Screwfix.
Personally I prefer DiLog but their cheapest offering, the Martindale, is absolutely fine.
Safe Isolation and Voltage detection kits from Master Lock and Martindale
Safely isolate electrical circuits with our safe isolation and voltage detector kits from Master Lock and Martindale. Be safe, use our safe isolation kits and voltage detector kit to lock off the RCD and MCB.www.test-meter.co.uk
Fluke T90 Voltage/Continuity TesterTry here, they have plenty of options at better prices than Screwfix.
If you can get a fluke t150 for a decent price then you won’t need to upgrade at a later date.Fluke T90 Voltage/Continuity Tester
Dilog Combivolt 1 - DL6780 Voltage and Continuity Tester
Martindale VT25 Voltage & Continuity Tester
Which one do I get or is there any better ones for similar price?
Hi bazaFluke T90 Voltage/Continuity Tester
Ok so If I buy a t150 I wouldn't need to buy a multi meter + a two pole voltage&continuity tester?Hi baza
When you first asked the question last week, I had in mind (prob incorrectly) that you were asking about a two pole tester for checking circuits are dead before working on them. The martindale I suggested is really mainly for that, and for very basic continuity. In addition I use a multimeter for fault finding etc.
If you want a safety tester that will also double up to do measurements (ie instead of having a multimeter as well), then you need something more advanced than the Martindale.
Personally I think the advice to go for the Fluke T150 is good, but I appreciate it's expensive.
If you check 'sold' prices on eBay, you can find a few that sold for £60 to £80 fairly recently. There is a risk in buying such (I wouldn't recommend the Chinese source) but at that sort of price you could probably sell it on if there turned out to be a problem! You might be able to afford to get it calibrated too!
I've bought literally thousands of items from eBay, and very rarely had a problem, even with electronics (eg TV circuit boards, appliance spares) although these days eBay prices can be higher than online retail.
Ebay bargain Computers, tablets, phones I keep away from!
I'm not too fussed on buying a two pole tester atm, I'd rather just buy a budget friendly multi meter for £10 and under lol prob won't get one for that much and test what I need to for now, I can buy the latter in the future. If it comes down to the mm being like £20 then i might aswell just throw another 60 on that and buy the t150
need to test socket readings to figure out if a circuit is on a ring or radialWhat exactly do you want/need the tester for?
A £10 multimeter will almost certainly not meet the safety requirements for use on LV, but would likely be ok for ELV.
If you mean by doing resistance tests, you would need a MFT or low resistance ohmmeter for that, which typically give readings to 2 decimal places.need to test socket readings to figure out if a circuit is on a ring or radial
can't i just use a dbl pole volt tester to see if the circuit is a ring or radial, it's a b32 mcb with 2 wires going into the Cb but, there's 3 sockets with single wires (1 socket use to have a switch spur for a floodlight but a electrician removed that recently since we didn't need it anymore) and then one socket with 2 wires entering it.If you mean by doing resistance tests, you would need a MFT or low resistance ohmmeter for that, which typically give readings to 2 decimal places.
I believe the Fluke T150 only has a resolution of 1 ohm, so your reading would be either 0, 1, or 2, not giving the accuracy you would need.
A cheap multimeter wouldn't really be suitable either.
A bit of (out of date) discussion here a few years ago: Cheapest Multimeter (low ohm - in - Electrical Tools and Products - https://www.electriciansforums.net/threads/cheapest-multimeter-low-ohm.190178/
You may as well find a cheap MFT for now, and it will also give you the experience of using one.Ok so If I buy a t150 I wouldn't need to buy a multi meter + a two pole voltage&continuity tester?
I was overthinking what you might be wanting to do in the longer term.can't i just use a dbl pole volt tester to see if the circuit is a ring or radial,
