- Aug 19, 2019
- 23
- 3
- 33
- United Kingdom
- Trainee Electrician
Hi all, just started a new job and I was shadowing another electrician. This was within a commercial setting as only 20% testing was carried out due to it being tested every year a full 100% would of been conducted at the end of the 5 years.
I was always taught to measure R1+ R2 and measure Ze then do the required formula to get Zs (Zs = Ze + R1 + R2) .
The spark picked 4 circuits and did not once do an R1 + R2. He just calculated it from his measured Ze and Zs of each tested circuit.
He said this is what others do. I know people do things differently from text book to real world but is this common within the commercial sector to do so?
I don’t feel like this is correct as I’ve never once been shown this way of testing. Would this be ok if I had access to previous test results and the value of the Ze and Zs values were similar on the old certs?
I’m still shadowing this spark but they are putting me out on my own in 2 weeks and I don’t want to be learning bad habits.He made out like this is common practice in the commercial testing sector. Confused. I do know how to test it’s just this one method that is confusing me. Should I carry on measuring the R1 + R2 or is calculation ok?
Appreciate your response's in advance
