Discuss Treadmill in garage tripping RCD in house in the UK Electrical Forum area at ElectriciansForums.net
I have now switched off all the circuit breakers in the house bar the one in the garage and the treadmill operates now without tripping. So I think the problem is the treadmill is exceeding the earth leakage when everything else is switched on.
To counter this could I remove the earth wire from the plug, and attach a copper wire to the metal frame of the machine which attaches to an earth spike driven into the ground, protecting the user from any stray current and effectively bypassing the RCD on the treadmill only?
Not to be recommended.
How would that stop the RCD tripping?
i have now switched off all the circuit breakers in the house bar the one in the garage and the treadmill operates now without tripping. So i think the problem is the treadmill is exceeding the earth leakage when everything else is switched on.
To counter this could i remove the earth wire from the plug, and attach a copper wire to the metal frame of the machine which attaches to an earth spike driven into the ground, protecting the user from any stray current and effectively bypassing the rcd on the treadmill only?
lol wtf
to counter this could i remove the earth wire from the plug, and attach a copper wire to the metal frame of the machine which attaches to an earth spike driven into the ground, protecting the user from any stray current and effectively bypassing the rcd on the treadmill only?
really????
It would stop the RCD tripping by leaking any stray current through to the earth rod in the ground and not through the earth wire! So the earth wire would have no feed back to the circuit breakers!
Balance Taffy,balance
In all fairness.we in Wales are only now discovering rcds,we tend to be a bit behind the times here
I can confirm I am not a sparky, far from it.
No it's not a new machine but is only around 6 months old, and has only been used a handful of times.
cant remember the makes,but I have come across 2 of these machines doing this and they were both motor faults and both machines around a year old,I think the previous owners knew this and sold them on, as the motors were about £300 each.
Clearly not used to the strict rules of this site... enjoy your ban ..... all swearing whether written, suggested, symbols etc is not tolerated!!!!!!!:ban:
Original comment by member deleted and a ban issued ....
Reply to Treadmill in garage tripping RCD in house in the UK Electrical Forum area at ElectriciansForums.net
