Apr 26, 2025
Tennessee
United States of America
Manufacturer / Distributor / Supplier / Inventor - etc
Hello. I have a piece of equipment that has been running fine for 2yrs but has recently began to shut off after running for less than a minute. I replaced the switch at the manufacturers suggestion which didn't fix the problem. The building has 3ph. The tool has a 5hp motor which is rated as 230v single phase. I did not purchase the tool myself and did not realize the motor was not dual rated for both. I have an electrician who's says it is pulling too many amps because of this (40 as opposed to the 19 amps it's rated for). He has suggested a transformer as a fix. My question is would this make sense even though it has run for 2yrs? Please excuse my ignorance on this and I appreciate any advice. Thank you.
First thing to do is measure the voltage at the motor terminals and compare with the rating plate.
A buck/boost transformer would be ideal to boost the voltage.
Tennessee
230v single phase motor on 208v 3ph
USA Electrical Forum
TonyWood,
norcal,
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician Laws and Regulations related to Electrics and Electricals within the United Kingdom. Electrician talk, questions and answers can be found in our UK electrical forum.
