Discuss 3kw shower! in the Electrical Forum area at ElectriciansForums.net
Deleted member 9648
Clutching at straws here methinks but I promised a client I'd do my best.
Scenario is a stable block being knocked down and rebuilt with the existing supply definately not being replaced. The client has asked if a shower head on a long hose is possible so that horses and dogs can be washed down with lukewarm water.With the other gear being installed the existing supply is only able to manage 3kw for the possible shower. Hot tanks and immersion heaters and other options have already been suggested and binned on cost grounds,which really only leaves the idea of a mains water electric shower with an extra long hose of max rating 3kw.
Anyone know of such a thing?
Marvo
Staff member
Mod
Mentor
Supporter
Have you looked at an LPG instant water heater? I'm not sure if a 3kw shower is going to be up to the job of washing down horses.
OP
Deleted member 9648
Depending on how often/long it would be used, could you not use a small over sink water heater?
Maybe,we had thought of using a standard handwash heater,but the spout connection on those are not the threaded connection of a shower hose,but an O ring push in type.Probably the same issue with say a 7ltr oversink unit.
Reply to 3kw shower! in the Electrical Forum area at ElectriciansForums.net
Hi. I'm being tasked with installing an electric shower into a property that was built back in the 1980's. The main consumer unit has only 4 ways...
Hello, I have just posted in the Electrician's section one photo and two videos of what I believe to be a dangerous situation of short circuits...
Yes a friend is trying to get as much low cost energy as possible, he has a water tank with top and bottom elements which runs of Economy7 through...
Hi all, I have a regular client who has asked for a battery back up system to be installed at their home. They live in a rural location on a...
Hi, I've got both a solar pv and an ashp system. The solar system also has 2 batteries and it's configured to fill the batteries first and then...
New Posts (Please Reply)
