P
pauljasonuk
Hello I posted about one year ago regarding certification software and would like an updated view please. I am an NICEIC contractor so would like to use this in some way or be able to use other software where I can place the logo etc on. I do not want to use the online cert on the NICEIC site as they haven't created the offline cert yet which is what I want. I'm going to be using an ipad. Your advice is welcome. I keep hearing icertfi or easycert a lot. Your thoughts welcome thanks. Paul Jason Electrical.
To get exactly what you want you could create your own certificates, then you would not need the redundant boxes from the NICIEC, and you woudl be able to put in whatever logo you wanted.
This is what I have done and it means I am confident in the software!
Easy cert good you can PDF the certs so no need to buy NICEIC blanks you can down load a free trial from their web site
I have Easycert for my ipad and laptop.
You can insert the logos and signatures quite easily.
The software is very good and saves a lot of time but my only criticism of it is that on the ipad it's easy to overlook inputting some of the data values because it's not intuitive. On the laptop, however 'what you see is what you get' so any omissions can be identified easily.
When I use the ipad I periodically check any missing values by producing the PDF, which will show the completed form.
Once you get used to it you'll wonder how you managed without it.
Personally I like the NICEIC online system, it produces professional certs which is all I need it to do.
Advice on certification software please
pauljasonuk,
uksparks,
