Discuss Best way to wire in new GU10 fittings in the Lighting Forum area at ElectriciansForums.net
won’t those things need fire hoods with standard lamps?
Only if they are in a fire-rated ceiling. That means a ceiling that forms part of a fire-compartment.
There isn't one in a normal house, except for the ceiling of an integrated garage. The ceilings of rooms in flats etc are a different matter.
True enough, but your local building inspector would get pretty ----ed, if you removed the plasterboard and exposed the ceiling joists. The plasterboard is there for fire protection of the wooden joists, so cutting holes in it for non fire rated down lights, kinda defeats the object.
Electrical Safety First recommends that fire rated down lights are used in all ceilings. The cost between the two are minimal, so I can't see a reason not to install fire rated down lights as standard.
Mind you, no ones banging on about extractor fans in bathrooms...yet.
Which some people translate into mandatory - which is misleading to say the least...
Great never seen those; this undoubtedly leads on to the question: if all cables entering accessories must to be secure, then why the design of the quick flow connectors without the clamps ? Are they designed for bigger cable, or rely on securing cable with a clip.
Who knows, why hasn't my favourite dram got a Government health warning on it :D
True enough, but your local building inspector would get pretty ****ed, if you removed the plasterboard and exposed the ceiling joists. The plasterboard is there for fire protection of the wooden joists, so cutting holes in it for non fire rated down lights, kinda defeats the object.
Sort of what I was thinking and then there’s the potential for insulation sitting on top of those fittings.
Apologies if I’m wrong but I gained the impression the OP wasn’t in the trade. I’ve yet to see a DIYer fit these lights correctly. Worst case being right against joists that were charrred due to the heat of GU10 lamps.
Reply to Best way to wire in new GU10 fittings in the Lighting Forum area at ElectriciansForums.net
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
Good Morning, I've used this forum for advice many times but this is my first time posting so I hope that this community can help! We're...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hi all, Disclaimer: I'm not an electrician and have very basic knowledge of electrical installation. We've been putting in a new kitchen into an...
