Discuss Containment spacing regs??? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi fella's,
Does anyone know the reg number for containment spacing?
I've just knocked up a shed load of containment giving a 50mm space between the trunking, tray and basket as told to do so. But I was wondering if there is an actual reg number according to bs7671;2018. The only reg I can find in the 18th edition is;
521.10.202; the support of cables in all areas will need to be prevented from premature collapse in the event of fire.
Any help is much appreciated.
Reply to Containment spacing regs??? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Doing a EICR in a college…there have been many over the years, it’s approximately 50 years old & improvement happens every so often. The new...
Related to another post, I am looking at running some network cable across a corridor above a false ceiling system. Is the ceiling support system...
Hi, I am new to this forum and hoping for some advice. Does anyone know if it's possible to get your hands on an old regs book, 14th edition prior...
Hello guys. This is my first post so go easy on me. I have had a install job at the company I work for currently. It is pvc 20mm conduit run on...
24K
Hi all, I had the following situation arise and was just wondering what others’ views were Doing a new build, started November last year...
5K
The Ghost
T
