footbal9584
- Reaction score
- 0
Hi!
DIY electrical guy here. I am hoping someone can point me in some direction on this. I live in Ohio if that helps. We bought this house a year ago and it has always been a problem. The general inspector didn't note anything really out of the ordinary with our setup, but he was not an electrician either.
Basically the problem is that whenever a larger electrical load (Stove, Dryer, Heat Pump, etc.) all the lights in the house dim for a second then come back up. We have no natural gas where we live so everything in the house is electric.
Now the details
I find our electrical set-up somewhat unique and have a couple ideas as to where the problem may be.
Outside a single line comes from the pole at the road ~120 ft where the main line continues to our neighbor's and a smaller line splits off to our house, each about ~60-75 ft.
Next from here, the 4 gauge wire runs ~30 ft to the main panel in this conduit.
Finally here is a picture of the two panels in the house, the main and the sub in the add-on/conversion. I can get one from the barn if needed. Any thoughts?
I know this a long post, so I thank you for your time and any feedback you may have. I am leaning towards calling the electric company about the outside line, but really don't want to open a can of worms that could potentially cost thousands right now if there is a chance that it is internal.
Now the details
- Here is where I think the first problem may be as the line coming to our house is only about 6-8 gauge off the main line shared with out neighbor's which appears to be 4-6 gauge.
- Here is where is I think another possible problem may lie. The line comes in on the other side of what I believe is either an add-on, or the old garage converted to living space. I am not sure if this is too long from the meter to the main panel. I am not sure if the meter outside was moved, or it was always here, but it does not appear that the meter or the panel were ever moved. However, the previous owner did not do this add-on/conversion so I cannot say for sure. Based on my research, it has been 20+ years since it was done.
