Discuss earth leakage in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Farmelectrics
got a new toy ha ha clamped my new earth leakage clamp around my earth cable local to consumer and was getting 5mili amp leakage question what mainly causes the earth leakage other than computers fridges etc
it was 8.6mili amps around tails and 6 mili amps on the earth cable no computers on tv is on and fridge and freezer what else could be causing this leakage
If its a Tnc-s system I suppose its possible that next doors earth leakage is finding its way to the neutral via yours
Sadly we pay for quality (real iPhone chargers ).
Plenty of TVs DVR ,DVD players are good for an odd milli-amp.
(the old transormers are too full of copper at 50Hz-hence replaced !)
a friend of mine told me he uses the clamp meter for his ir tests dosent do any ir testing just calculates the ir from the leakage current he detects whats your thoughts on that says it saves him lots of time still need convincing that this is ok
Does sound dodgy ,if no one else can get same figure with 500V .
Can see where he is coming from Not having to unplug all those delicate electronics (they get tested at 380-400VDC)
its a good idea and would save you lots of time quick clamp and calculate and onto the next one or better still the pub quicker. would be good before a board change
Reply to earth leakage in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
