Discuss earth leakage in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Farmelectrics
got a new toy ha ha clamped my new earth leakage clamp around my earth cable local to consumer and was getting 5mili amp leakage question what mainly causes the earth leakage other than computers fridges etc
Sadly we pay for quality (real iPhone chargers ).
Plenty of TVs DVR ,DVD players are good for an odd milli-amp.
(the old transormers are too full of copper at 50Hz-hence replaced !)
a friend of mine told me he uses the clamp meter for his ir tests dosent do any ir testing just calculates the ir from the leakage current he detects whats your thoughts on that says it saves him lots of time still need convincing that this is ok
Does sound dodgy ,if no one else can get same figure with 500V .
Can see where he is coming from Not having to unplug all those delicate electronics (they get tested at 380-400VDC)
Reply to earth leakage in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi all Suggestions please. I’m working on a 3 phase shop install with a bunch of typical circuits. As each cct is energised the earth leakage...
Hi all, There's 2 single fan ovens in the house my mother recently moved into. Posh elecronic AEG units. It's been sat empty for a year, so the...
I WAS ONCE SHOWN HOW TO CALCULATE INSULATION RESISTANCE USING A CLAMP METER. SO I NEED HELP AS IVE FORGOTTEN. CAN ANYONE HELP WITH THIS FOLLOWING...
