- May 3, 2021
- 8
- 1
- 33
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
Hi everyone,
I recently installed the Heatmister Neostat HC to control my wet underfloor heating and AC. However, I’ve encountered an issue: this thermostat doesn’t have ports for floor sensors. Since all the floors in the property are wooden, I’m concerned about overheating the wet UFH, which could damage the flooring.
Could anyone suggest a device that I could hide inside the back box and set up to limit the maximum temperature? I want to avoid any potential overheating issues. Thank you for any ideas.
