Discuss House consumer unit to garage consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Hi all
I’m planning to install a consumer unit in my garage. The unit will eventually power a 32amp hot tub, 2 double sockets and a small lighting circuit.
The distance from the house CU to garage CU will be about 10m. I plan to run single cables through 20mm steel conduit under my concrete drive once I cut a channel which will exit in the garage.
1. Is it advisable to run singles or T&E through the 20mm conduit?
2. What size cable is preferable (10mm)?
3. What size RCD/ RCBO should I use in the house CU to supple the garage consumer unit (50amp)?
I am an ex electrician who has been a naval engineer for 12 years now so I’m confident I can complete the work myself. Any advise/ comments on my 3 questions would be really helpful. Thanks
Hi all
Any Bonding requirements ?
1 Don't use conduit the cable size will be limited
2 Have you done any calculations to ascertain what size cable will be required?
3 The choice of OCPD size depends on far to many imponderables to just guess, employ an electrician to design and install this installation for you.
Hello. Use swa it is easier and elimates need for rcd protection at house end. Cables size all depends on what your going to do in the shed
Thanks for your reply.
Not 100% certain on the earthing arrangements planning on just using the earth from the home CU. Decided I’m gonna use SWA (10mm) through a small duct as I also want to run a cctv cat5 along side it.
Been reading through my 17th edition & part p but still not clear on the calculations as it’s been a while. what size RCD/ MCB to use at the house end to supply the garage CU as I’ll be powering a 32amp hot tub from the garage CU?
We are on the 18th edition now.
An this is all very basic.
I suggest employing someone competent to design and install for you. We can't offer step by step guides on here, against forum rules.
Hi all
I can't believe a supply through a steel conduit underground. How stupid can you get. What's wrong with a steel wire armoured. ? I despair for the trade.
Reply to House consumer unit to garage consumer unit in the UK Electrical Forum area at ElectriciansForums.net
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
Hi all, what is the best way to configure surge protection in domestic dwellings when you have multiple consumer units? Does each consumer unit...
4K
Hi, just helping someone out and apologies for the long winded post. Would like install a couple of weatherproof double sockets on the patio. 1...
