uHeat Banner - Forum Discount Available
Discuss House consumer unit to garage consumer unit in the Electrical Forum area at ElectriciansForums.net
Hi all
I’m planning to install a consumer unit in my garage. The unit will eventually power a 32amp hot tub, 2 double sockets and a small lighting circuit.
The distance from the house CU to garage CU will be about 10m. I plan to run single cables through 20mm steel conduit under my concrete drive once I cut a channel which will exit in the garage.
1. Is it advisable to run singles or T&E through the 20mm conduit?
2. What size cable is preferable (10mm)?
3. What size RCD/ RCBO should I use in the house CU to supple the garage consumer unit (50amp)?
I am an ex electrician who has been a naval engineer for 12 years now so I’m confident I can complete the work myself. Any advise/ comments on my 3 questions would be really helpful. Thanks
Charlie_
You must be logged in to see the message.
Midwest
Charlie_
B
Bobster
  • #18
J
Jjc
Pete999
Pete999
SuperlecDirect - ElectriciansForums.net Electrical Suppliers
Reply to House consumer unit to garage consumer unit in the Electrical Forum area at ElectriciansForums.net
Aico 3000 Range
Top Bottom
