M
mobile_mouse
Hi,
My Samil SR3300TL has started to throw a DC INJ High fault.
Rebooting the inverter seems to sort it but it looks to happen when we have a lot and close to max sunshine, probably a Cap failing somewhere and we have had a lot of sunshine recently. Most times it reboots in 10-15mins but once it didn't come back till next day...
My installer informed me Samil UK did a runner and left us all high and dry when it comes to warranty, this unit is 5ys old.
My 1st question is do I need to inform my DNO of an inverter change...
Q2: Can I fit a larger Samil inverter they did a SR3680TL which should have better electronics inside.
Or would you fit an alternative PV is 3.25kw.
My concern is, is the inverter maxing out and stressing the output under max PV, and any equivalent be lower in output than the present Samil.
Your help and advice would be appreciated...
